03 x-type passenger air bag light intermittent
light goes on/off dependent on location of seat back. I have seen postings on cleaning contacts of air bag connection but I cannot figure out which connector belongs to the air bag and which to the seat location controller. Some of the comments do not seem model/year specific?? Help!
Stephen
Stephen
Me again with more complete info
Car was inundated, roof left open during nighttime rainstorm. Wife opened windows, raised seats, lowered seat backs all the way in attempt to accelerate drying. Seats back in upright position did not respond to her weight - airbag light came on. When I sit on seat with back in upright position light goes off. When back is reclined way back light comes on, but goes off when back is upright again. (I can make light go off by leaving back in reclined position but sitting upright - just to confuse things more) I suspect a loose wire making/braking contact depending on location of back. Anyone, have an idea to fix - or just to trouble shoot further?
Stephen
Stephen
Location: That Rectangular Hole in the Consciousness of America
My '02 has the same, 'intermittent' problem - although it is more often than not anymore, as I have yet to address it.
The code that the airbag light gives me (search this forum for how to read the code from the light, and what the codes mean) indicated a bad ground (and/or maybe something else, I forget what). In spite of "refreshed" connectors (read: WD-40 and wiggle, disconnect-reconnect x5 times, etc) it continues to appear.
DO NOT BELIEVE most any of the codes you get, as you KNOW the problem is moisture / corrosion. You do NOT need any new parts, in all likelihood.
Methinks undoing one seat mounting bolt, and running some emery cloth 'twixt the seat and the body to clean the mechanical connection, might be the fix. Please try it and see if it works (also spray WD-40 in all the connections you find down there - wiggle 'em, etc)
Dealer price for fixing this problem likely qualifies as "expensive".
The other "fix" is what I currently employ: a small square of electrical tape to hide the warning light.
Bruce
Thanks for the reply.
Here's what I did: Disconnected battery, undid bolt holding electical connector left side, front passenger seat (with side branch connector having plastic latch needing a push in to release. Is this the airbag connection?). Compressed air to make sure that everything was dry, then Radio Shack connector cleaner. Jiggled connectors to assure good connection. I assume that the ground is good since the controls for the seat position work. Everything back together. Test. Same results - airbag light comes on when seat back in extreme reclined position.
I suspect that the connectors are not the culprit but the wiring up the back (is there wiring up the back?) is the problem. I saw somewhere else a video about removing the cover of the back, but that was for another model. I'll have to go back and try to find that again. Otherwise I am stumped. My wife is talking a new car! She is the one who sits in that seat!
FS[Western US]: XJS Wiper Motor Upgrade- 76-88 - Electrolux Style
XJsc-guy
09-02-2015 11:43 AM
