03 X Type running lights
Received 3,905 Likes
Tony, what are you attempting to do? When you say running lights, I am thinking the small lights on the car in the front (high beam housing) and the side marker lights, along with the tail lights on dim (those are what I call running lights). If you are talking about the fog lights, then that is nothing more than pulling out the headlight switch. Could you possibly be talking about daytime running lights? If you are talking about daytime running lights, then that is nothing more than swapping out the headlight switch for a daytime running light headlight switch. Please keep in mind that you will have your choice between "canadian" daytime running lights and "Scandinavian" running lights. The difference between the two is the canadian ones keep the headlights on all the time (any time the car is running) and the Scandinavian ones will actually kill the front beams when only the parking lights (ie, side marker lights) are on.
Hopefully this has answered your question.
BrentGardner
28
04-26-2024 03:08 AM
stanjag
08-30-2015 10:35 AM
