03 xtype 2.5 sputter when take off
Old 09-27-2010, 04:00 PM
ghachey's Avatar
Default 03 xtype 2.5 sputter when take off
seems that when I put the pedal down it sputters a bit then accelerates, only at low speeds, only 96000 kms on it. Any thoughts?
Old 09-28-2010, 11:25 AM
sidewalkman's Avatar
Have you tried to run some fuel injector cleaner through a tank of gas yet. Sounds like dirty injectors.
Old 09-29-2010, 05:49 AM
ghachey's Avatar
just put some in yesterday, cross your fingers lol
Old 09-29-2010, 10:24 PM
rand49er's Avatar
There can be only two possibilities: fuel or spark.
My money is on fuel being the issue. Either too much or not enough.
Ques: Did you put the injector cleaner in because you noticed a problem or did you notice the problem after you put it in?
Old 09-29-2010, 11:27 PM
I <3 X-Type's Avatar
Well i would suggest if you are thinking fuel, changing the fuel filter. That is a huge culprit with fuel flow. Plus its easy as hell to change out, plus its cheap. Just curious too, no check engine light?
Old 09-30-2010, 11:03 AM
ghachey's Avatar
no check engine light, put the injector cleaner in after I noticed the issue, going to have it in for an oil change early next week, will get them to put in a new fuel filter, I appreciate the advice !
Paora
02-04-2021 12:36 AM
Finbarr1975
10-04-2015 05:32 PM
Newark Nj Gang
10-02-2015 02:39 PM
Lubrication
10-01-2015 03:56 AM
caldoofy
09-28-2015 08:43 PM
Quick Reply: 03 xtype 2.5 sputter when take off
