03 Xtype windows fogging up
Might want to check the recirc door is not stuck closed. Raise the hood, remove the retainers on the plastic cowl panel at the base of the windshield. lift up on the panel and you will see the pollen filter. remove the filter and you should then see the recirc door. use a screw driver and push it up and back. It spins on an axis so up and back should work. Reinstall the removed components and test the system. Don't touch the recirc button as the same thing will happen. The recirc motor tends to strip the gear on the recirc door and it will get stuck closed, causing the misting of the windows. Also, make sure the A/C is fully charged. Make sure the pollen filter box is not clogged with leaves and debris.
Cheers,
aiko670 (02-02-2012)
Thats one of the minor niggles with my new to me jag sorted then
I`ll get my other half to change the pollen filter at same time me thinks
Search and yee shall find
fiona
blackenedindustries
09-30-2015 10:17 AM
