'04 Jag x-type 3.0 - Gear Box failure
Forum,
I have had intermittent gear box issues over the past year. In the past it would only happened when I was parked and the car wouldn't go forward or reverse. I don't know if this was the correct thing to do but I just restarted the car and it would fix the problem.
The other day was different, as I was driving about 30-40 mph the car suddenly wouldn't accelerate, as if i was in neutral, I luckily had enough momentum to get to the side of the road.
I shut the car off and restarted and it got me going but after 40 yards as I was driving, it happened again. I kept the car in neutral, restarted and the car worked for about a mile until I returned home.
I haven't used the car since 2 days ago when the incident occurred.
Does anyone have any ideas what the issue may be?
SharkStopper
SharkStopper
Or check the shift connection on the transmission for correct setting. Has a tendency to wear and change the ability to shift correctly.
Make sure to read the embedded solution thread, too.
https://www.jaguarforums.com/forum/x...-fault-206869/
AZ RICH
06-12-2018 01:35 PM
