05 motor into an 03 X-Type?
Received 3,932 Likes
Robo, you should be able to swap them out without any issues. These are pretty much interchangeable with no issues. All the sensors and whatnot are the same.
Not to add more work and/or cost to the job, but this would also be a good time to give the transfer case a rebuild to ensure you can have fun with the car without having to worry about a transfer case.
Five Speed (06-10-2014)
Robochop, I would say if you have it out on a stand, I would undo the bottom of the tranny and see if there is a filter there or not. Ican not say that anyone has removed theirs to put a new one in, but I would anticipate something to be down in that area that you could potentially remove to get rid of any large chunks.
I was referring more to the transfer case than the tranny itself. If you are going to have issues, you are more likely to have it with the transfer case. Since you have things in pieces now, getting the transfer case out would be a piece of cake.
That just brought up something else that you may want to consider. Since you have the engine out, now would probably be a prime time to do any work you would want to do on the oil pan. Probably a good time to put in a new gasket as these are known to start leaking and be a real PITA to get to once inside the car. The big problem being the one bolt that is hidden behind the mount for the transfer case.
Thanks again for all of your info. I am also having trouble with hooking up the starter. it has 3 connectors, but I can only find 2 wires. The red battery and a small wire. The small wire is easy, but not sure which terminal the red one goes to. there is a nut on the solenoid and on on the bottom that goes into the starter. Are there any wiring diagrams on the site? Thanks, Robo
Jaguar Forums Editor
Jaguar Press release
09-19-2015 10:18 AM
09-17-2015 11:18 AM
09-17-2015 01:08 AM
09-16-2015 03:08 PM
