05 x type 3.0 intermitent no start
Hey Guys, New here. I've got a 05 x type 3.0 AWD that has a Crank position sensor problem. Started at begining of this summer when hot and shut off, it wouldn't start back up right away. Got so bad it finally set a code for the crank sensor. Replaced it and worked fine for about 3 weeks and happened again. Replaced it again and lasted 3 days. After you run it for a while, 50 miles or more, if you turn it off most times it will not restart. And if it does, it sounds like a diesel and will hardly pull itself out of it's own way. A few times i've been able to restart it quickly and it will go away. Now it is setting a P0335 CPS A circuit malfunction code. Been thru another sensor (got one from Ford) but still happening but not as frequent. Checked pins at ECM and plug, all clean and none bent. Pulling my hair out chasing this! Any suggestions?
Thanks, Jim
Thanks, Jim
1964Daimler
09-02-2015 11:41 PM
stanjag
08-30-2015 10:35 AM
