05 x type vdp auto lights/sonrrof issue. First jag ever
![Icon Doh](https://www.jaguarforums.com/forum/images/smilies/icon_doh.gif)
Are you sure you have the switch in the correct position for the lights? Not having a manual might be the cause of your problem (actually when I first got my car the manual explanation of the lights confused me a bit). It should be in pointing to the light bulb icon with the "A" in the middle. If you have it pointed at the icon of the headlight with the rays pointing down at an angle you will have to turn that off when you stop the car.
As for the sunroof, to open it fully you should be pushing on the arrow pointing to the rear of the car. To close it hit the arrow pointing to the front of the car. That front arrow also controls just popping the roof open a little bit at an angle. Hope that helps.
Hope that helps.
Hope that helps.
stanjag
08-30-2015 10:35 AM
