'06, automatic, 3.0L ...starter replace?
Every once in a while starter doesn't engage. Spins but no crank. Wondering if these have separate solenoid? Or.... is there a how-to on changing the starter in an automatic? Seems the manual trans starter change is straightforward, but the auto is different and I'm not finding it using search.
Ok.... I read it. ![Smile](https://www.jaguarforums.com/forum/images/smilies/smile.gif)
That whole thing about supporting the drive train using that big jig sounds like overkill if I'm reading right.
I went out and looked at this and tried to follow what I was seeing and matching it up to the instructions.
Remove the battery box, I understand.
Support the transmission using a jack and wood block, I understand.
Does that mean I actually REMOVE that support bar? I see the one (forward) starter mounting bolt goes through a hole in that support bar. Is the "support bar" actually bearing weight? Like.... is it an engine mount? Or is it a stabilizing bar?
This really doesn't look like that bad of a job as long as I don't do something stupid by not supporting something when I loosen up that bar.
If some one have not done the job he should not give an advice! I replaced my starter last year, two things I haven't done: 1st I only disconnected the battery cable but didn't need to remove the battery and the tray, 2nd I removed the support bar but I didn't need to support the trany, but if you do it will make you feel safer.
swingwing (01-28-2017)
