07 X type 3.0 p1367 + 9 others
So my girl was really needing a tune up, so I had purchased and installed new sparkplugs, coils, both camshaft position sensors, the crankshaft position sensor, all 4 02 sensors, and a full ac replacement. Everything went smoothly during the job but as soon as I started her it wasn't right. I do want to state she starts every time I try, idels up fine and after 1 to 2 seconds starts miss firing. Attached is all the codes currently getting thrown. I've searched the forums and due to everything being new, I'm having difficulty locating a similar topic.
please point me in the right direction someone
Obviously you know these are misfire codes. First check is you having done numerous things (plugs, coils, etc.) Is check the wiring to the coils and also ensure the grounding points are cleaned and making good contact.
Next would be check your IMT's. Then brake booster (both the "bulb" check valve and the connection where it enters the manifold), then the breather hose (should be the crosshatched type). This one often fails underneath.
Lastly with 1, 3, & 5 it could well be you need new valve cover gaskets.
https://www.jaguarforums.com/forum/x...-codes-212970/
EDIT =
Or there is that! Lmao! Glad you found the problem.
EDIT =
xjrsteve
11-26-2012 12:50 AM
