'07 X-Type Starting Problem
![Question](https://www.jaguarforums.com/forum/images/icons/icon5.gif)
Experiencing problems starting my '07 X-Type automatic. Will start after frequent attempts to start but it is hit and many misses. Gauges light up, lights come on, clicking sound when key is turned and red light on transmission console comes on when start is attempted. Tried battery charger. No improvement. Suspected weak battery so attempted jump start from healthy battery. No improvement. I suspect faulty starter or other component. I expect battery will have to be replaced (unsure of age but test will confirm its condition). Car is completely unreliable and requires MANY attempts before starter will engage and start the engine (it starts immediately when starter engages and car can be driven). Before taking it for diagnostics, I would like to be prepared so I'm not paying for unneeded work. Your thoughts??
brianwalker (04-27-2017)
Cables were replaced 2 yrs ago so should not be the source of the problem. I'll check them anyway to be sure
Thanks for the advice. Cables were replaced by the dealership when I purchased the car in '15 so they should still be good. But I'm going to check them anyway just to be sure. I suspect the battery is weak (not sure of the age, could be original). It was the inability to jump-start that made me think it might be starter or ECM or TCM.
When you did the jump start did the starter just spin over and the engine not crank? If the starter didn't spin the there was no voltage to the starter. You might have a bad starter relay, or maybe the fuse to the relay is blown. Look for a 30 amp fuse and check that it is in good condition. Then try swapping the the 2 relays on the left and right side of the fuse box closest to the radiator.
