1647 code help please
Old 09-10-2012, 07:12 PM
dvd711's Avatar
Default 1647 code help please
1647 code
05 x/type 2.5
replaced upstream O2 sensor/bank2
cleared code and came right back
cleared code again and lasted until next day, when eng. started next day code came back immediately.
Noticed oil residue on the intake manifold above and around lower IMT.
Did not notice hissing but will vac leak there cause this?
Will this cause 1647 code???
Old 09-10-2012, 08:28 PM
Gus's Avatar
Gus
Gus is offline
Received 2,212 Likes on 1,702 Posts
Not an expert in this area or on your X-Type but you should see if you can get a graph reading on your 02sensors to get a better idea of what is taking place. Have you considered a reset on your car now that you replaced the sensor?
Old 09-11-2012, 05:32 PM
dvd711's Avatar
hey gus
Thanks for reply but cleared codes twice. Also, asked if this could be caused by IMT orings as oil residue was found around lower IMT.
philwarner
25
06-26-2021 05:43 AM
bdboyle
09-16-2019 05:58 PM
Terry H
07-04-2017 05:48 PM
JCam
10-23-2016 08:27 PM
philwarner
09-02-2015 11:45 AM
Quick Reply: 1647 code help please
