19" Wheels Help!
The fronts may rub slightly on your fender liner when turned at full lock but otherwise youll have clearance for miles.
If you do decide to lower the car (which you probably will once you realize how high it looks with 19s and a 4x4 stance) you will definitely need to roll fenders/possibly run narrower tires depending on what you go with.
You'll want 225/35/19 with a 40mm offset (assuming fender rolling won't happen). There is no real difference in ride, performance or curb protection from a 225 to a 235.
scooternva
19
10-27-2015 02:14 PM
lickahotskillet
09-11-2015 07:54 PM
