2.0D Starting issue - repost with added info.
Can anyone shed any light on this issue, surely someone has had this problem before.
Come to start in the morning it will fail first time coil light flashing but start 2nd time no issues and sometimes hot after being driven say if its left 10-15mins etc.
It runs for like 1-2secs and stops.
It will fluctuate sometimes its fine, sometimes it starts 1st time, sometimes it starts 2nd time so on and on and its been like this for quite a while.
Parts replaced
Clutch, flywheel and starter very recently.
Injector Seals.
Cam Sensor approx 2 years ago
***Extra Information***
Sometimes in the morning like this morning it failed to start first time, coil light flashing after it failed, but did start the 2nd time.
Diagnostics i found no codes stored on the ecu
I did mechanical diagnostics in the way off.
Removed the drive belt - turned it off and on again numerous times and it starts fine no issues.
Removed the belt and crank pulley again turned off and on again numerous times it starts fine no issues ?
Checked the crank pulley which seems fine no damage no knocks is not loose and is the uprated one.
any clue at all, it was suggested theres air in the fuel, but problem goes away if belt removed, just don't get it.
Parts replaced
Injector Seals.
Uncle Fishbits
04-13-2022 05:12 AM
KittyVet
05-31-2020 11:57 AM
