2 Degrees Outside. Noisy Car.
It's 2 degrees Fahrenheit here in MD today. I heard a lot of new noises coming from my X this morning on my commute to work. Seems like I can hear every gear in the car whirring and whining. Cold transmission and t-case fluid, I suppose?
I also heard a loud, intermittent ringing, which would increase and decrease with the speed of the car. Came and went at random. I'm thinking that was the carrier bearing?
Anyone else experience these noises when driving in extreme cold?
Stay warm.
Stay warm.
Received 2,263 Likes
I live in upstate NH and drive the Jag in a lot of cold weather.
When it is exceptionally cold, I hear some strut/shock noise, and yeah, the transmission "whines" a bit more than usual. I imagine the trans fluid is just really, really cold.
Also, I try to let the car warm up a bit before kicking on the heater....I have heard some AWFUL noises if it is super-cold out and turn the car on and immediately turn the heater on full.
Once it is warm, though (or I have driven a ways), almost all the noises die down.....
It's just cold, I figure.
Location: That Rectangular Hole in the Consciousness of America
If you get another 5 or 10 degrees colder, your X-Type will start singing like the fat lady in the opera.
My favorite of the X-Type cold weather songs is the Constant Velocity Joint doing it's own Aria (noun: aria; long, accompanied song for a solo voice, typically one in an opera) with a strong, syncopated back-beat from the flat spots on the frozen tires.
That is some crazy music!
Others are the Fanbelt Fugue, the Transmission Trombone, the Transfer Case Toccata (watch out for that one: each stanza ends with the bells of a cash-register ringing!), the Drive Line Drum ("Boom Boom Boom goes the Drive Line, Thump Thump Thump goes your heart"), the Dragging Brake Baritone, the Power Steering Pump Sonata (a lovely song, sung either in "turn right" or "turn left"), and the Windshield Wiper Waltz (you'll be waltzing on the ice around the car as you run to break the frozen wipers free of the window whilst the growl of the wiper motor accompanies).
Like the "Boom!" of Kettle Drums? That is what the Regulator of a frozen side window sounds like when it fails, as you try to open a frozen-shut window. Piccolo's? The sound of the squeak you make when you see your cold-weather mileage.
Come on, kids. help me here.
The X-Type is a veritable Symphony of cold weather sounds. The only one you don't really want to hear is "Crunch"!
Others: (please add to the list)
* ABS Staccato
* Windshield Warm-up Rhapsody
* Frozen Electric Mirror Miserere
* Frozen Lock Lament (kind of a Gregorian Chant, or maybe a Funeral Dirge)
* Heavy Metal Head-Bang
* ABS Staccato
The following 5 users liked this post by Bruce in North Dakota:
clyons (01-07-2014),
Dr dome (01-07-2014),
GLH (01-07-2014),
Mikey (01-07-2014),
rclangelan (01-07-2014)
Bruce, you must be a musician. I'm glad I decideded to not drive my 2005 in the winter, only run it around the park, no salt, on warm days to keep her moving. Couldn't decide if I should store the car or leave it outside so that it could be run occasionally. I bought a Florida car and it doesn't have DSC so it's probably not as good in the snow as my Escalade AWD, but I don't know.
Anyway, Im guessing all those noises can't be good for the car.
* ABS Staccato
* ABS Staccato
Excellent.
A bit over the top, but there's a grain of truth in there!
Bruce in North Dakota (01-08-2014)
Bruce in North Dakota (01-07-2014)
I've seen worming in up a bit - and pushing the gas slightly while in nuetuel - drive the noise away - also Turing on lights radio also helps -
I have a ? On the oil I'm using now Castrol Edge 5W30 full synthetic - I've heard we should switch to thicker oil what's you experience ? Especially in cold areas
Stay with the 5w.
Your Variable Valve Timing depends on it, summer and winter.
Jaguars do not need "thick oil". If you change anything, go 5w10 for winter.
You drive a Jaguar.
It's engine is built (re-engineered, to be correct) to the HIGHEST of tolerances. Your X-Type ain't your Daddy's Ford Taurus - even thought Ford 'built' it. It is a World Class Motor Car, built to the umteenth of balances and tolerances.
"Thick oil" is for 'filling the gaps'.
Your Jaguar has no such 'gaps'.
You may safely take a frozen Jaguar X-Type from well below zero degrees F at start-up to over 100 miles per hour - without warm-up - without ill effect.
Keeping the oil 'fresh' is the trick.
//Vehicles in Rear-View Mirror are loosing
You drive a Jaguar.
Richard_gib
09-12-2015 07:08 PM
