2 tires or 4 tires
2 tires or 4 tires
I have a bubble on my left front tire, so I will be replacing it. I know with All Wheel Drive you need to at least replace 2 tires at a time, so my question is should I replace just 2, as the tires aren't too worn, or would it be better replacing all four.
I cannot find locally the same tires that are already on the car, so I am leaning towards 4 tires so they all match, but with a kid on the way I could use the cost savings of only buying two, what are the pros and cons of buying just two?
That isn't exactly correct. Every time you drove your tranny/transfer case fluid heated up by allowing one axle to spin faster than the other. This type of fluid will quickly deteriorate due to the higher temps and no longer do its job. It is definately not something one should willingly do.
Yes. Think of it this way. The diameter of a tire varies based on the amount of tread. If the tires on one axle is worn more than the other then the one that is worn will need to spin more often in a mile than the other. No big deal on a f or r drive car but for an awd or 4wd car this is an issue. A part time 4 wheel drive system can only be driven off road or in slippery conditions which allows the tires to be corrected by slipping (same with around corners but that is a different story). If you drive a part time system on a dry road you'll understand what binding is. On an awd or full time 4wd system there is something which allows the slippage to occur internally allowing for the car to be driven in the dry (i.e. transfer case, tranny clutch packs etc depending on the manufacturer). The bad thing is this creats heat and in turn wears the part rapidly that is designed to provide the compensation. AWD cars need 4 tires of the same make and tread pattern with equal tread wear so rotation is a must for this type of vehicle.
IMHO, get one or at most two tires. A certain amount of slip is engineered into the system, and tires having different diameters (we're talking millimeters here) can be accommodated and will wear in. If the car wears out, get another one.
Mind you, if you're loaded with $ AND are ****, get four tires.
yeah, think about how many x-type owners there are and other all wheel drive system cars are out there. You think that if someone gets a nail in their tire they are going to replace the whole set. Maybe here on the forums yes, because we are into our cars but to the common folk that aren't into their cars like we are they will just go and get that one tire replaced. Maybe two so they can have them match on the axle. Just my thinking...
thanks for responding,
can anyone agree with this?
(it's not like i don't believe u, i am into cars, i like to take care of them and I am a student so i don't want to pay for big bills either)
if yes, what tires should i get?
i am on a budget, are continental extreme DWS are good or any other cheap tires..
I just had a flat on my X-type with Conti ProContacts that were getting quite worn (50K miles). I called a number of tire shops and not a one of them would just replace 2 tires because of the 4 wheel drive system. Some of my engineer cohorts agreed and some didn't. Since they don't sell tires, I ended up getting 4 Conti Extreme Contact DWS to replace the ProContacts. Haven't had them long enough to make any judgements other than they are much quieter than the ProContacts.
FS[MidAtlantic]: 1997 XJ6 VDP $3,900 - Very RARE Anthracite on Warm Charcoal
42Ajd
09-26-2015 07:04 PM
