2001 jaguar x type 2.5 lambda sensor
Hi all could some one please tell me the location for the lambda sensors on my 2001 x type 2.5 sport. As some one has hooked a lambda sensor under my bonet to nothing i mean its just cable tied on to the wiring loom. There are two wires coming from the lambda to a plug on the bulk head next to the coolent bottle. however the are also two wires that have been cut so a total of 4 wires .
So im thinking that a lambda has failed some were and the previous owner couldnt get it out so he has just bunged any sensor on and cable tied it on under the engine covers.
Also the car did not missfire when i brought it home. Only after i washed it, So i suppose bucket of water and lambda sensor dont go well.
![Icon Sad](https://www.jaguarforums.com/forum/images/smilies/icon_sad.gif)
Abit of an update iv just got in from having another look the wire that were cut and joined to the lambda under the bonit were BLUE SOILD and WHITE / GREEN. I removed the lambda that wa just cable tied on to the loom. and joined the wires back to the gray connecter.
But the missfire is still there not on tick over or whilst reving at a sand still only when the engine is under load. Also i still do NOT have an engine light on the dash. I have hooked a live wire tester up and the blue wire seems to be pulsing fine in time with the engine.
All Jaguar models initiate a three second indicator lamp check when the ignition is switched on. Exceptions to this are the Airbag light remains on for six seconds, High Beam and Indicators are excluded from the check.
Your MIL should illuminate for three seconds during this check. If it doesn't, either the bulb is gone or someone has been deliberately interfering with it.
swarm27
08-29-2015 07:37 AM
