2002 2.5 auto cranks but won't start
Old 03-04-2013, 10:53 PM
Corycarlo's Avatar
Default 2002 2.5 auto cranks but won't start
Any help would be great. I have a 2002 2.5 auto with 80k on it that's only a month old to me. The car ran great until today. I drive it home from work, ran fine, and then parked it for about 4 hours. After the four hours I came back out, hopped back in it to run errands and it just won't start! It cranks right over but doesn't begin to catch. Any ideas? Like I said, it ran great and started right up earlier in the day, parked it and now it won't start but will crank fine. It have about a quarter tank of gas in it. Fingers crossed it an easy fix.
Old 03-05-2013, 12:09 AM
Bud Tender's Avatar
Do you have or have access to an OBDII code reader?
If you can get it running, several of the large auto parts chains will read them for free.
Old 03-05-2013, 05:13 AM
Corycarlo's Avatar
No, that's the issue... It won't start. And I don't have a code reader either. Any other ideas?
Old 03-05-2013, 09:04 AM
Alfadude's Avatar
If everything was fine with it and now it won't start it could be as simple as the battery. It might have enough juice to turn it over, but not enough to get it to start. Our cars our pretty finicky for failing without warning. Maybe take your battery out and get it load tested. I know when mine went there was no warning whatsoever. No hard or intermittent starting. One day fine, the next morning nothing.
Old 03-05-2013, 09:47 AM
Corycarlo's Avatar
Ok. My battery light has been coming on randomly. I will just that. Thanks!
Old 03-05-2013, 12:08 PM
Bruce in North Dakota's Avatar
Location: That Rectangular Hole in the Consciousness of America
Turn the headlights on and crank the car over. If the lights dim way down, the battery is shot (you car see it in the interior roof light, too).
Sometimes the information on the "Climate Control Center" screen will look all funky when you're cranking it, too - when the battery is munched.
Whomever sold you the car just dumped an old battery on you. If it was a dealership, go yell at them and make them at least sell you a new one at cost or below.
Attached Thumbnails 2002 2.5 auto cranks but won't start-used-car-salesman-2-thumb.jpg
harvey_birdman (08-09-2013)
Old 03-05-2013, 01:35 PM
Alfadude's Avatar
So it was running "great", except for the random battery warning light coming on. That was a big thing to leave out of your original post. I guess that kind of answers whereto start looking. Hopefully it is just a battery swap.
Old 03-05-2013, 02:51 PM
Corycarlo's Avatar
The battery is reading just over 11 volts. Turned on the radio, headlights, and heater and tried to crank it. Nothing dimmed down much at all. I unscrewed the fuel rail valve stem and pushed it in and no fuel came out. Would a slightly weakened battery make it so the fuel pump wouldn't turn on or does it sound like a bad fuel pump?
Old 03-05-2013, 04:10 PM
Corycarlo's Avatar
I'm going to try a buy a code reader today and will update with any codes that come up.
Old 03-05-2013, 07:19 PM
Corycarlo's Avatar
Only 1 code popped up P1111. Any ideas? I'm thinking fuel pump
Old 03-05-2013, 08:42 PM
Corycarlo's Avatar
Bump. Any ideas from the Jag experts?
Old 03-06-2013, 01:54 PM
Corycarlo's Avatar
No fuel pressure at the fuel rail, could that be from a worn battery or is the fuel pump shot? Also should I check the fuel relay first ?
Old 03-06-2013, 08:14 PM
Corycarlo's Avatar
Anyone out there willing to try and help?
Old 03-07-2013, 03:48 AM
maybe try this. (Is a link to a .pdf file about the fuel pump cut off inertia switch
Old 03-07-2013, 05:02 AM
steveinfrance's Avatar
Sorry about lack of replies.
This isn't my model so I can be wrong (often am) but 11V is no good.
Before assuming you've got a dead fuel pump you really do need a battery reading over 12V.
Your fuel pump is controlled by an electronic module and it is possible that it isn't turning the pump on because of the low voltage.
With a decent battery can you hear the pump running when you turn the ignition on?
It should run for a few seconds and stop.
Old 03-07-2013, 11:48 AM
Corycarlo's Avatar
I will get the battery checked after work. Thanks for the input!
Old 03-07-2013, 05:18 PM
Corycarlo's Avatar
Advance auto parts results
Voltage 12.15v
Measured 408 cca
Rated 640 cca
Temperature 52^F
They says it fine just needs a charge, prob from me cranking it. Ok. On to the next thing. I bought some more gas to put in it, the needle was touching the red and when I parked it, I parked it on a slight incline, maybe the fuel isnt getting to the pump. If that doesn't work I'm afraid it seems like a bad fuel pump
Old 03-07-2013, 06:20 PM
Did you do the reset of the inertia switch?
Old 03-07-2013, 07:50 PM
Corycarlo's Avatar
Yes, it did not seem to be tripped. Thanks for the idea tho!
Old 03-08-2013, 02:54 AM
Check there is volts getting to the pump - if you haven't downloaded JTIS from the HOW-TOs then that will help with wiring diagrams etc.
Quick Reply: 2002 2.5 auto cranks but won't start
