2002 3.0l auto trans - level plug location
Ok guys, I feel like the dumbest guy in the room. Searched all over the forum (and google) and under my car but I cannot locate the trans fluid level plug per the photos that have been posted. I found the tranny fill and drain plugs as well as the TC plug.
Any help would be appreciated. Apologies in advance if perhaps I am missing something obvious.
The fluid level is checked @ 35 degrees centigrade. Here is a Rover bulletin.
Freelander - Gearbox Fluid Level - Plug Location - Land Rover
The JATCO JF506E is used in the VW jetta, Rover freelander and Jaguar X-Type.
Level plug is the 5mm allen socket on the bottom of the gearbox.
Don't remove or loosen ANY OTHER BOLTS!!!!!!!!!!!!!!
I just did a quick google search for JF506E fluid level check and found lots of info.
bob gauff
bob gauff
Thanks gold_04, I did look at your picture but I was not sure if that was from the 3.0l auto.
I found it, and please excuse my ignorance. I was expecting the plug to be on a vertical surface not on the bottom (I did not realize that your pic was taken directly in an upward direction.
Thank you everyone for your assistance.
Wolfy
05-28-2024 08:06 AM
