2002 3.0L Cooling System
Old 10-22-2006 | 02:21 PM
racerx82's Avatar
Default RE: 2002 3.0L Cooling System
Haven't had that problem nor have i heard anyone else.
The 2 areas i would double check is the temp sensor, left sode of engine block(i think) and the fan control relay located next to the left fan (drivers side)
The temp sensor, even though it checked out according to the scanner, may not be closing as temp decreases. Once it opens as the temp increases, it just maybe that it sticks in the open position. The scanner won't pick that up....since it won't give a trouble code.
As for the fan control relay, have your mechanic check it for the ohms resistance...that might be stiking in the open position as well, keeping your fans on longer...(the timer circuit is in that as well)
hope this helps.
________
Starcraft 2 Reaply
Old 10-25-2006 | 11:15 PM
racerx82's Avatar
Cool (no pun intended) :-)
________
Bmw e83
way2far
08-31-2022 10:26 AM
cissdm
05-03-2016 07:02 AM
Dicque
09-19-2015 01:53 PM
1100me
09-07-2015 07:26 AM
Numwen
09-06-2015 01:30 AM
Quick Reply: 2002 3.0L Cooling System
