2002 manual x type wont go over 3000 rpm
X Type wont rev over 300 rpm
My car is doing the same thing. No one seems to be able to tell what is wrong from the codes. Replaced knock sensor, plugs, manifold gaskets, vacume lines, maf sensor, and it is still doing it. I am wondering if it could be Cat Convertor.I am ready to go nuts. Fast right up to 3,000 rpm. Any suggestions?
Clean the map sensor, you can buy a spray for this, remove 4 screws and disconnect electrical give a good cleaning, I had the same problem with getting up to 3000rpm then stutters cleaned the map sensor no more problems.
