2002 manual x type wont go over 3000 rpm
Old 06-24-2012, 06:01 AM
jagman_irl's Avatar
Default X Type wont rev over 300 rpm
Originally Posted by markwh60
My car is doing the same thing. No one seems to be able to tell what is wrong from the codes. Replaced knock sensor, plugs, manifold gaskets, vacume lines, maf sensor, and it is still doing it. I am wondering if it could be Cat Convertor.I am ready to go nuts. Fast right up to 3,000 rpm. Any suggestions?
Did you ever find out what was wrong with your. Going nuts over here, jaguar Belfast cannot fix it.
Old 06-25-2012, 03:42 PM
ulster49's Avatar
Clean the map sensor, you can buy a spray for this, remove 4 screws and disconnect electrical give a good cleaning, I had the same problem with getting up to 3000rpm then stutters cleaned the map sensor no more problems.
Shawn Svacha
11-04-2019 02:47 PM
montypeek
09-06-2015 04:57 PM
easylender
09-01-2015 12:56 PM
roumor
08-28-2015 01:02 PM
brent65622
08-26-2015 08:41 AM
Quick Reply: 2002 manual x type wont go over 3000 rpm
