2002 X Type 2.0L Automatic
If anyone has had these problems i would be glad of all the advise i can get......
Code 1638....can problems
Code 1603...... TCM problem
I fully charged the battery, then installed a new TCM, i removed the IC and did a pin test....ok....checked the wiring connectors as far as i could reach but the engine will not crank. The IC lights up as normal but turn the key and it just refuses to crank. I removed and cleaned the battery to chassis grounds. After which i am thinking ECM....is there a way to pintest the ECM.....Any answers will be greatfully accepted, and any other information the same.
KarimPA
09-03-2015 07:32 PM
