2002 X-Type cigarette lighter not working
If your fuses are fine, you can physically check if the plug is connected to the back of the lighter. You could do this by removing the J-Gate wood surround (snaps right off) and than you use a torx screw and remove two screws and than the ashtray comes right out and exposes the wire that is connected to the lighter.That way if your fuses are fine, you can see if it somehow it got unplugged or even the little plastic clip that holds it into place broke, their made really cheap, or maybe a burnt bulb?
