2002 X-Type crankshaft position sensor
kh: The crankshaft position sensor is on the 'front' of the engine, to the left of the crankshaft pulley. To remove it, disconnect the single electrical connector and loosen the single bolt. When you install a new sensor, take care not to over-tighten the bolt. The spec is 7 ft lbs (10 Nm), i.e., hand tight.
RoyLittle0
05-25-2023 02:38 AM
