2002 x type cruise not available/gearbox fault
Hi hope you guys are able to assist me. Was driving home one evening and stopped to the gas station and purchased fuel. Shortly afterwards my car displayed "cruise not available/gearbox fault and went into limp mode. The following i purchased lucas gas treatment thinking it was only bad quality gas. this did not work. car remained in limp mode. Therefore i had the codes pulled and it indicated Engine control module/transmission control module as well as a code for o2 sensor. There is also a smell of exhaust and gasoline. Can someone explain to me what is happening and what needs to be done. Thanks much for any assistance.
Im planning on driving my 2002 Jaguar xtype to New York from Arizona but check engine light and abs light is on.. the car has 113k miles but I'm trying to figure out what services I should have done before traveling.. in need of some help
As for your issues, there are a lot of things that could cause a check engine light to come on. Some very simple, cheap and easy to address, some, not as much. Best thing is to go to one of the chain auto stores and have the codes read and post here or do a search. That will pinpoint things down quite a bit and someone will be able to help you further.
As for the ABS light, could be something like a wheel speed sensor or a reluctor ring that has corroded.
Just a tip for the future, it is probably better to start a new thread instead of adding on to one that is so old. Good luck getting your issues addressed!
