2002 x type headlight replacement
I have tried to replace the low beam headlight bulb on the passenger side of the car. I have unclipped the two wire clips and tried to remove the black plastic cap that covers the light on the inside. The cap moves easily on the right hand side but the left hand side (toward the fender) seems to be attached somehow in the upper corner. I didn't want to use force to try and remove it. Is there something else that holds the black cap in place? Am I missing removing something? If anyone else has replaced the passenger side bulb I would appreciate some help as to how you did it. Thanks.
Then just hope the bulb socket has not melted to the
the bulb! Mine is on the left side headlamp. Need to
tap the light to get it to come on most of the time.
I am going to get a ceramic socket and rewire both
low beamsafter I get my damn ABS issue fixed!
Those plastic cups are a pain too!
It's beena while since I replaced mine, but I think there are just two clips that hold the cap on. I remember getting them off wasn't a problem, it was putting them back in that was a pain. About a month after I changed the bulbs, I discovered a dead spider in the headlight while I was washing the car. It was on the drivers side, which from what I remember was the harder side. I took the cap back off, but could get the spider. Finally, I took my air compressor hose and blew air in it from behind and the spider came out somewhere.
Good luck. It's just two clips but what a pain.
Paul
Paul
Thanks for the info. I approached my dealer about this issue and was real surprised that he said to bring the car in and they would do the job for gratis. I know, I know, there probably will be some sort of cost here. But hopefully it will be minimal (again, I know, I know, its a Jag dealer). Anyway, my hand is already all scraped up from my first failed attempt and nothing has been damaged to my knowledge. So if the cost is low I will be ahead of the game. By the way a piece of strong wire like a metal coat hanger bent into a small hook works fine to reattach the inside clip.
It's quite easy really - just need one of those long mini rollers used for painting behind radiators -(without the roller, of course), tease it in, push far clip off and pull it back on when done
Housing moves to the side and downward with some gentle teasing
just thought I might add a couple things that I found worked well this weekend when it it warmed up enough (-10 C )to change the low beam bulbs again.
Reading most of the posts it seems it is recommended to remove the bumper to change the headlights. Being as that was too much for me to tackle at this time of year without a garge I discovered it is possible to change change them ( as long as you don't mind having more skin under the hood of the car than on your hands at the end of it) and doing most of it by feel as it is very hard to see anything after your hands are in there. One trick I did discover however ( not sure if it is an x type problem or all jags) is when you go to reattach the cover, there isn't enough room to get your hand in to pull the clip back over the cover.
If you have kids and a trampoline use the hook shaped tool that removes the spring to grab the clip and pull it to lock the cover in place. Another tool that I actually found worked as well was a nail puller ( not sure what everyone else calls it but it is essentially just the back of a hammer that is attached to a handle) it also fits into the small space nicely and grabs the clip easily.
stanjag
08-30-2015 10:35 AM
