2002 X-Type Key worn down/wont turn
Guest
Posts: n/a
Greetings --
Over the past year or two, Ive noticed its gotten harder and harder to simply insert and turn my key to start my car. As of recently, it takes a good 90 seconds of wiggling in order to get my key in just the right spot to be able to turn it and start my car. I have a funny feeling it wont be long before I wont be able to start my car at all. I noticed my old key ( the one ive used daily for years ) is smooth and worn down. So 3 or 4 months ago, I started using my extra key for the first time since Ive owned the car. It worked well for about 3 weeks but now its worn down and doesnt work any better than the old one. I occasionally notice very small metal shavings from time to time in my floor mats underneith my ignition. I dont know what to do here. My question is this: Can I order a used or salvaged ignition assembly and have it professionally installed at my local service center in order to save money ( times are tough people! ), or is this a situation where I will be forced to purchase a brand new ignition system and key set from my dealer? And is there a chance something else could be causing this alltogether? Thanks in advance for any advice guys!
![Unhappy](https://www.jaguarforums.com/forum/images/icons/icon9.gif)
I am having the same problem with my 2003 X-type. My will not turn at all now. I am surprised the factory doesn't do a recall to fix the problem as it is quite wide spread. I will take the car in next week. The dealer thinks the Lock Cylinder is bad. Will need a new cylinder and new keys programmed to the car. Could be expensive ....
Mechanical wise, Itll be 90% more the key than the locks. The old Tibbe design wasnt all that great to begin with. Because of the way the key works in the lock (Its boring so I wont go into detail) the wear on the key is at a guess 30% more than a 'normal' lever locks. (Basically on a Tibbe lock eveything moves about 5 times more than a normal lock) (As Noted above, the dealer will say its the lock.... theyre a LOT more expensive than a replacement key, but my experiance is itll be the key)
Problem is, once its worn down, its worn down. Even getting a duplicate made (eg another key cut) off the old key will still give you the same problem. Best bet (and its sounds like its to late now) always keep a spare origional key (If you have one when you got the car- And cut working keys off that origional,
A Jag dealer will be able to cut you a new one off your VIN, if you a rich, or...
Im unsure where the key code is on an X, but try the drivers door lock. You can get a key cut from that code and itll be just like a new one. Tibbe blanks are easy to find off Ebay, however I dont think they have all the buttons on them. Just search for 'Jaguar Tibbe key' They dont look as sexy as the real Jag key, but do have a few buttons on them so they look ok at a screen only look.
Dont spray WD40 etc into the lock, youll only cause damage to the lock mech and internals.
We have a spare key, not used much, tired it also with no luck. They both work fine in the door, but not the ignition. Does anyone have any idea what a repair shop will charge to replace the cylinder and keys? I have contacted an import car repair shop who said they could do this, but could not give me an estimate until I bring the car in.
![Icon Shrug](https://www.jaguarforums.com/forum/images/smilies/icon_shrug.gif)
Wolfy
05-28-2024 08:06 AM
