2002 X-Type w/out nav
Welcome to the forum nationalpartks,
I've moved your question from Jaguar Forums Feedback & Suggestion Centre to X-Type forum. As stated at the top of the Feedback & Suggestion Centre ...THIS SECTION IS NOT FOR TECHNICAL QUESTIONS.
Received 3,932 Likes
nationalparks, the short of the answer is "with enough time and money, you can make anything work with this car". Now, for the realistic answer. For what it will cost you to get all the incidentals, you could probably trade in your current car and get one with it already installed and still be a few hundred to the good. It is not just a simple "unplug one radio and plug in the other". There are a lot of additional modules that you need to get to make the nav work and then you also have a wiring harness to get to link all these pieces together. so, if you have a spare weekend on your hands, you should be able to get it done in that time. But, I would also recommend finding a local wrecking yard that has an X-Type with the Nav system so you have a source to get all the bits and pieces that you will need.
Thanks for responding thermo I actually have the whole 03 x-type for parts everything is in it and working except it has a jvc aftermarket stereo in place of stock with all wiring and nav unit in trunk and DVD player as well in trunk
so your saying it is possible I was worried about the climate part of it thanks for the help
nationalparks, remember me saying that you have a lot of modules that will need to be transferred over, you will also have work with the A/C system too. At a minimum you have a blower motor to add next to the steering wheel and I believe you need to change the actuators on the blend doors to the new system too. Like I said, not hard work, but there will be a lot of stuff that gets transferred. You are going from a mechanical system to a fully electronic system.
Preacher-Steve
10-08-2016 10:43 AM
