2002 Xtype Replaced Ignition Won't Start
Received 3,915 Likes
Normg, to see if the key is sending the signal all the way to the ECU, simply look down at the center console as you are attempting to start the car. there is a coin holder there by the e-brake handle. On that is a red LED (should blink periodically when the car is locked too), if it is blinking when you are starting the car, the car is blocking the signal to start the engine. You should also see a "Security Failure" message on the instrument cluster.
If you are not getting either of these, then you may have a fuel issue. If you need more help, let me know and we can step through things.
