2003,3.0 jaguar xtype battery light
Hi guys,
My jaguar always lights up the battery warning but I have no ideas to find out the reasons.
Here's my situation:
If the car's temperature is cool, the battery light will burn if I use my air-condition while I just started the engine. But it won't lights when I use air-condition after I have driven for few meters or minutes later.
Second, if the car's temperature is normal it will light up when I restarted the engine. And I think it won't charge since the lights shows up.
I already changed battery and it's cable. I also replaced a new dynamo few days ago and it doesn't work. I still saw the light.
Hope you guys can let me know how to solve the situation like this.
Mike
Mike
Thank you for the reply,
I replaced my positive cable and the problem disapeard for few days.
But after those days, the same situation showed up.
Therefore, I will check my ground cable.
If the ground cable is fine, does anything else causes the problem?
hafren
08-30-2023 03:42 PM
Andrew McVey
16
08-27-2015 07:21 PM
Terrance Williams
08-26-2015 11:50 AM
