2003 Front Passenger Door won't open from outside
Hi Rusty,
Thermo mentioned giving a squirt of wd40 into the locks and maybe inserting paper towel or something absorbing into the gaps below on the door to take out some of the residue.
A hard push on the door can sometimes help so that you hear it click into place as if the door had been not quite seated properly.
https://www.jaguarforums.com/forum/x...oor-faq-48827/
Hope this helps? Stu (please bear in mind, you need to add your vehicle spec and engine size/model to your signature so other members can identify your problem and also, some of these details differ compared to different models.
Good luck, Stu
Good luck, Stu
BrentGardner
28
04-26-2024 03:08 AM
Andrew McVey
16
08-27-2015 07:21 PM
