2003 Jaguar X-Type brakes locking up
Welcome to the forum Cwhite71,
I've moved your question from General Tech Help to X-Type forum. Members here with the same model will be able to help.
Received 3,915 Likes
Cwhite71
Read post 4 in the link. That should fix what you have going on.
https://www.jaguarforums.com/forum/x...ocking-211141/
Brakes locking up
Will this also take out all the pressure thats in the pedal?
Cwhite71
dont buy another booster again its a simple adjustment 15min job without taking any hoses of ...just unbolt the master cylinder whatch not to drop the nut on the right ,pull back the booster out the way , have friend push the brake pedal all the way in now you can see the rod ...now get a needle nose pliers and hold the shaft ,then put a 7mm socket on the end and turn it in about 3-4 turns clockwise in ...and voila your done ...
LnrB
11-01-2018 06:52 AM
