2003 X 4x4 Automatic. Bad solution?
Guest
Posts: n/a
Guest
Posts: n/a
RE: 2003 X 4x4 Automatic. Bad solution?
I dont know about the X having a problem, but AWD and part Time 4x4 do have more problems than you standard FWD and are more expensive to fix. But with every car ever made there will be problems some different some the same.
I had the same engine problem with the3 oldsmoblies i owned, all different year and models. Either its just bad luck, the way i drive, or old's suck?
If you like the car buy it every car will break eventually
neruda
10-18-2015 01:19 PM
kabs3012
09-12-2015 10:40 AM
