2003 X Type stalls when taking foot off gas
![Question](https://www.jaguarforums.com/forum/images/icons/icon5.gif)
I have been searched through the posts on this great site since I started having an issue with my X-Type. There have been several similar issues, but none seem the same. Hopefully the experts here can steer me in the right direction.
First off, my car is a 2003 X Type, AWD, 2.5l, with a manual 5 speed. The car has about 165,000 miles on it. For an older car, it drives well and has plenty of power. To this point there have been no major issues.
Here is the problem. When I am driving the car will stall in two situations. First, if I am driving on the high way and take my foot off the gas to slow down using the engine for braking. Second, when I take my foot off the gas during a shift it will stall. Besides for these two situations, runs like a champ.
To try and diagnose the problem I bought a blutooth OBDII sending unit and the torque app for my phone. I have monitored several different aspects of the vehicle and found that the problem is fuel pressure. When I remove my foot from the gas, the fuel pressure dips...sometimes to zero. After the pressure drops, the car will stall and then restart after a few minutes of 'rest.'
Not sure what is going on. Any input will be appreciated.
Thanks,
Joe
Thanks,
Joe
You don't mention if you are having any check engine lights when this happens. Do you have any codes that show up? If so, please post as that could be a great help in diagnosing your problem. I would think something is showing up as you mentioned having vacuum problems. I'm sure before too long someone here will be able to get you on a path to getting your X back in good running order.
By the way, welcome to the forums. If you haven't already done it, please introduce yourself to everyone here in the new members section.
Location: That Rectangular Hole in the Consciousness of America
Pull the fuel filter again and dump it out, see if it just didn't fill up right back up with crap.
There could be an incredible amount of water in your tank if an ethanol blend fuel was used, on the order of more than a couple of cups. You might have to dump water out of it repeatedly until the problem is resolved
Even though you've swapped out the old filter, your description of the problem is still a classic fuel starvation due to a plugged filter.
These were the symptoms I experienced when my fuel pump first started to give up. I never did figure out what it was about lifting off the throttle that caused the pump to quit. Wait a couple minutes for it to cool down and it fired right up like nothing ever happened. I figured the fuel pump might have been heating up enough to barely seize (this was in the summer). Anyhow a month or so after this started and about 6 random occurrences just as you described, the fuel pump failed altogether.
Twice it happened in exactly the same spot- right where I started to coast to exit the freeway. 2002 2.5 X-type
AlphaDude:
No engine error codes anymore. There were codes for lean on bank one and misfiring on multiple cylinders. Once I sealed the vacuum leaks, the codes have not returned.
The only code that I have at the moment is for the rear wheel speed sensor. I must have bashed it when I changed a wheel bearing. New sensor will get installed this weekend.
Bruce:
I will try replacing the filter again. Will the filter on a gas engine collect water? Thought that was a diesel thing. Either way, it will be $10 well spent if it helps.
Thanks all,
Joe
Bruce:
Thanks all,
Joe
When the engine dies or is turned off for a few minutes, those water molecules fall off the the filter media and gasoline can again flow through.
The main culprit for water in the fuel is ethanol blended gasoline, especially if the tank isn't kept full all the time. The ethanol is hygroscopic - it readily absorbs moisture (water) straight out of the atmosphere. If the tank isn't completely full of fuel, that water can condense back out of the fuel and collect at the top and sides of the fuel tank, and pretty soon you end up with a lot of water in the tank.
If you pull the filter again and indeed find water in it, just slap the new filter in and put the removed one some place warm where it will dry out (as long as the stuff that came out of it wasn't filthy, too). You might have to repeat that a number of times, if there is an excessive amount of water in the tank.
A 16 oz can of Seafoam brand gas & oil treatment in a full tank of good, non-ethanol premium gas can help "dry" the tank out, too. (Heck, the Seafoam just might be all you need to fix the problem, too. Works great!)
Of course, if you don't find water in the filter, as Batman mentioned you might be looking at a new fuel pump.
Best 'o luck!
Joe kelley the reason you car is stalling is because of the speed sensor. Abs light on right? It is a known fact that the abs reluctor ring corrodes on the rear drive shafts and falls off. When the ring falls off, the sensor has nothing to pick up, so it thinks the wheel is not turning. Check out the uk forum
www.jaguarforum.com/f26
There is more information regarding your x type there than any other forum on the net.
Ryan
Ryan
stanjag
08-30-2015 10:35 AM
Terrance Williams
08-26-2015 11:50 AM
