2003 X-Type What to do's?
Goodevening everyone!
My Carrier bearring in drive shaft is going out 1280$ dealership quote.
Upper Coolant Hose leaking 800$ dealership quaote
Those are my two foremost concerns.
I talked to my father in law prior to the final quote and he suggested to just replace the bearring, the dealership said somthing like it is intergratted and needs a whole new drive shaft.
I'm flabbergasted at the 800$ pricetag on a coolant hose...
I'm not too savvy with cars, but I'm sure I could figure it out if it is possible by an average joe, is the upper coolant hose replaceable by me and do I find a different shop for my carrier bearring issue or just go with British Motor Corp?
I appreciate all and any help! Thank you very much in advance!
Carrier bearing should really only cost about $200 if you're doing it yourself and maybe $500 at tops from a reputable shop. You will have to buy the bearing from here Jaguar DRIVESHAFT CENTER SUPPORT CARRIER BEARING - EBC9040-OE for $130 and then take it to a shop with a press so they can press the old bearing off and the new bearing on. I can't really help you with the coolant hose cause it could be many things. Is the coolant leaking?
yes the coolant is leaking, I noticed it about 1 1/2 weeks ago, my heater was blowing cold when the car reached peak temperature, I immediately pulled over and checked the fluid and it was extremely low, so I filled up with what I had accessible and moved on and it fixed the problem for the meantime.
BMC said the hose will be dripping soon and if it blows off I'm stranded, they have my car right now and expect an answer by tomorrow, they are just making it out to sound like it's impossible for anyone else and difficult for a skilled tech to do the hose. " it's long and wraps in and out and around the engine"
3jagfamily
10-01-2015 01:49 AM
SoCalJagS
09-27-2015 09:20 AM
