2003 X-Type wheels advice
Aquill 1,
I like your wheels. They are simple and nice.
The reason for not choosing the 18 is because I do not want to compromise the ride and I know that I have more "oportunities"to scratch them.
Chris X,
Well, besides the Jag (which I use everyday) I do have another car which I use only in the Summer.
I really HATE to change wheels, I love my Jag as is and I am really keen with the car but since is an AWD I don't think I need another set of wheels. I will keep the OEM for the next owner (they have BFGoodrich All-season on them) and they are not the best ones and I managed to go through a really harsh winter (last one), the harshest one I have seen so far. And if you can drive a FWD without the proper tires then an AWD with good tires will make a big difference. Also the winter in here is really long, starts in October (this Saturday we expect snow) and goes in April-May. Many times you will see people who put the summer tires too soon and suddenly a snow shows up and they are stuck.
PaulXType,
I thank you for the offer, I will gladly come to a warmer place...
regarding the hockey, I must dissapoint you, I do not know anything about it...
I am from Europe and I am more interested in Formula 1 and Racing.
I must say that I envy you for the fact that you guys run in performance tires all year long... Damn!
Chris X,
PaulXType,
Well if you choose to run one set all year long, might I suggest you put a healthy coat of wax on those new wheels to help protect them from the winter elements.
Also, look for a set of tires that lean toward cold weather compounds and more aggressive tread, since you drive something else in the summer. I suggest Continental Extreme Contacts, I have them on my Saab and they run very well in the winter snow, slush, and ice.
And don't tell your neighbors you don't know hockey, they might throw you out of Canada.
With 18's the ride wasn't really any worse. I also had the sport model which is a little stiffer. Scratching isn't a problem with rims, bending them is...BTW this is also what salt/heat/cold/brake dust/snow can do, one word of advice would be to keep the rims clean.
My 17's rubbed more than my 18's did...
I assume the lip was chrome and this is kinda common with these wheels...
Tha aluminium with a plastic over it or painted wheels are better for winter.
I was reading on RIAL's website that they have a good warranty on paint job so I think they will be fine. If not, **** happens, I will see.
I am still waiting for the wheels. I have oredered Michelin Primacy MXV4.
They haver the best rating in quietness, handling, winter traction and comfort. I will let you know how is the ride.
#30
It's a toss-up. Most of the polished aluminum wheels have a clearcoat over them, as do the painted ones. It will just come down to how **** you are about keeping them clean. Bending them is the hardest part to avoid, sometimes you don't see that 2ft pothole until you are in it.
I hope that you don't have problems and if you do the wheel company stands behind its warranty without all kinds of fine print b.s. and extra charges. I wouldn't trust em.
The Michelin's are a solid tire, a good choice short of dedicated snow tires. I've found that getting going is not the problem, it's the stopping that gets hairy, and that's dependent on your tire compound.
#31
Nope, not chrome they were aluminum lip with the crappy plastic coating. It doesn't really matter what it is, everything gets corroded.
Just keep them clean and get brake dust off of them. It seemed like the combination of salt, cold, heat, brake dust and water went to town on them. The painted silver parts will be fine it's anything that has metal exposed (regardless of coating) that get torn apart. I had a set of mangel brand rims on my truck that had the exact same problem.
#32
^ yep, agree with you there.
I did use the product "Zoop Seal" on a set of aluminum rims I had for my old Saab 900 turbo. It was a pain in the butt to use (had to have the tires off) and it is kinda expensive, but it works good to repel just about everything. I know the truckers love the stuff for all of the chrome and diamond plate they have.
If I were running nice chrome or aluminum lipped rims in the winter, I'd probably spend the $ and take the time to coat them with Zoop.
http://www.zoopseal.com/
#33
Ok, my wheels came in, TunerWorks put them on, they look nice.
I took the car home last night, today I was planning to wash the car. Surprise! My wheels are rubbing my interior plastic covers!!!!
I am really really disappointed...
DZTT, home come they work for you ?
I really don't know what to say, and now I am stuck with a set of wheels that don't fit. The tires are 225/45/17..
And I just throw away
1800 bucks...
I am starting to hate this car... really...
1800 bucks...
#35
What is the wheel width? 17 x ? If they are 7" wide there should be no rubbing but if the are 8" wide, you may need a thin spacer to bring them out slightly. Or, do they only rub on the front when you turn them fully left or right? The tire itself could be slightly larger than another tire. There is very little space to go above 25" with any set up.
#37
hello mohrd,
First of all thanks for your reply!
The tires are rubbing only when max turn.
The liners are a litle bit "inflate" towards the tire...
I was thinking today to gram a gun heater and try to push them in...
Any ideas? I really love the wheels though
#38
#39
Hey Aquill,
I bought these wheels because I wanted new wheels. I always wanted new OEM rims but the dealer has an insane price and I wasn't able to find new ones anywhere else.
I have replaced many things in this car and it seems like always is something...
Anyway, I went to the car wash today (yesterday I was so upset that I gave up) and put the car in the garage.
I grabbed my hair dryer and with a new pair of garden gloves I start heating the liner and push it towards back.
It seems that it worked and now is good. i will put some pictures tomorrow for others to see.
Sure I was mad, I was thinking already: " Now I must buy two liners too... *&^#@*
Oh, I wish to had this car brand new... then everything would be different.
#40
If you do get some pics up we could help you come up with some ideas of how to eliminate the rubbing. If they only rub at full lock it's not that big of an issue. But we need to see where they rub......Using the heat gun is a good idea.
On my jeep I had some rubbing issues with 33 inch tires. A sawzall took care of that. LOL...of course that wouldn't be the way to go in the Jag. But some strategically placed zip ties (cable ties) on the inner liner could solve the problem.
