2003 xtype bad HID ballast can i replace with aftermarket?
2003 xtype bad HID ballast can i replace with aftermarket kit as a new ballast is 400 dollars US and a new kit is like 75 or cheaper ? and if i can how would i go about hooking it in to the old harness as its different from a halogen harness
I am a little confused. First do you have factory HID?
If so the ballast is square and turns CCW to remove.
The wiring is a plug in. You will see a slot and can use your fingernail to push the connector off.
Look on ebay for Genuine Xenon. They are a seller and the ballast fits the Jag and they are reasonable.
I just installed one on the passenger light on my 2002 x-type
brent65622 (08-27-2015)
Here is a link to the ballasts I use:
Hella Xenon HID Igniter Ignitor Mercedes BMW Audi Jaguar 5DD 008 319 10 | eBay
They had a reasonable price and free shipping. They ship priority mail and delivery is
pretty quick.
pretty quick.
mine has a factory ballast mounted under the headlight assembly and the igniter plugs into it Factory 02 03 04 05 06 07 Jaguar x Type s Type Xenon HID Headlight Ballast | eBay like that
The one you are showing would work fine. Do you know for sure that it is bad. You should swap with the working light each component and see what fails. If not you might want to consider this set since it has both.
BMW E53 E60 E65 E66 E85 E86 Xenon Ballast Ignitor Igniter Set Controller Unit | eBay
rudelover2
09-11-2015 08:53 PM
Andrew McVey
16
08-27-2015 07:21 PM
Terrance Williams
08-26-2015 11:50 AM
