2004 Jaguar X Type - Radiator Fans Issues
A while back I had an issue with my radiator fans not turning off after the car was off. After doing research, I figured it was my radiator module, so I replaced it. After replacing it, the fans now turn off when car is off, but when car is on the fans run at full speed the entire time.
I thought maybe it was a faulty radiator module, so I bought another one and it did the same (sent it back and got refunded).
After more research, I found that it could be either the coolant temp sensor or a fuse (f16 - 5amp) which I’ve replaced both and still the same issue.
It’s been this way for awhile, everything else works fine on the car so I didn’t care but I’m looking to sell the car soon and would like to fix it before I do. Any suggestions would be helpful.
I also seen some info about it possibly being a bad ecu, if that’s the only option than I’ll just sell it as is because that sounds expensive. Thanks in advance, any help would be really appreciated.
link: https://www.ebay.co.uk/itm/183307255...mis&media=COPY
Notice the 4 pins on the Gates correct FCM. The others usually only have 3. Yours looks like 3 =
See the 4 pins on this offering as well in their pics
https://www.jegs.com/i/Gates/465/FCM...hoCb0AQAvD_BwE
Valerie Stabenow
E type ( XK-E )
10-27-2021 06:12 PM
