2004 manual trans slipping
I have something as rare as hen's teeth, a 2004 X-Type 2.5 with a manual trans. In fourth and fifth gear, on anything more than light acceleration, the trans seems to slip out of gear, like the clutch isn't fully engaged.
The clutch totally failed on me about 120,000 miles ago, so is it time to replace the clutch or is the pedal adjustable?
The car has 247,000 miles on it. Many major systems have been either replaced or repaired, so it's like a new car.
Uuuummmm.....120,000 miles is not abnormal for a clutch to bite the dust, particularly if you do more in town driving than freeway. You can replace it yourself, not really rocket science type of repair. Alldata says 16 hours, but that is an experienced mechanic charging you out the butt for labor. That's why the cost is so high, not the parts.
I'd also replace the slave cylinder while in there just for g.p. And the dual mass flywheel on petrols (gas) are not as susceptible to the "wobble" failure as diesels, but check it anyways.
Partsgeek kit includes the slave cylinder for just under $250.
If it's slipping (versus popping out of gear) it's almost definitely the clutch. Popping out of gear (ie the shifter actually moves back into neutral) is a different issue and trans related). Slipping when applying significant torque in higher gears is the classic first symptom of a worn clutch. Since the clutch is actuated hydraulically there's no possibility of an adjustment issue like in a mechanically activated clutch or failure mode that would result in a slipping clutch.
@Tumble = you can do it by not removing the engine. Take a look on youTube for a video.
Quote =" trans seems to slip out of gear, like the clutch isn't fully engaged."
Note: NOT FULLY ENGAGED, not "popping" out of gear.
Classic clutch sign.
chargerrich
03-22-2014 03:16 AM
