2004 X-Type 3.0AWD starter replacement
I've done that, it's not hard if you got a pair of small hands (so every thing on the X-Type), remove some bracket around there, need some ratchet extenders, push some wiring harness aside to make room, remove two bolts that attack the starter to the fly wheel housing, pull the starter out, remove the battery cable, (sorry , you must disconnected the battery first)
