2004 X-Type Battery draw
Hi All
My Wife's 2004 X-Type has had an issue with a low buzzing sound in the dash that we have not been able to locate. The problem is if we do not drive the car at least once a week the battery will be drained and the car will not start. Has anyone else had this issue and if so what is the fix? I thank you all in advance for your ideas.
Dave
Dave
As Steve says, it's probably the cabin air temperature sensor fan that sucks cabin air in and measures its temperature as part of the climate control system. It shuts down some minutes after you turn off the ignition and remove the key. (Stay in the car and wait and listen!) It also starts up again as you open the door the car.
Removing the small plastic grill and blowing the crap that accumulates in the fan that feeds the sensor with a bit of compressed air (like for keyboards) sometimes helps quiet it down. After reading about the "buzzing" complaint some months ago, I checked mine out because I had never heard it. Mine is so quiet, you have to put your ear right next to the grill to hear it running. I still took the grill off to blow it out & it looked like a cat hairball that came out, lol.
Hi All
Thanks for the advise. I have had to replace the battery twice over the past 3 or 4 years. The buzzing is always on even after shutdown and removing the key. The buzzing will kill the battery if the car is not restarted in a 7 to 14 day period. My gut feeling is a relay is stuck thus closing a circuit which drains the battery. I had heard that this was a common problem with several different models thus was hoping that the cure would be easy to locate. I guess I just need a bit of a push in the right direction.
Dave
Dave
It is common to think that the aspirator is not shutting down. It comes on every time you open the door. Doesn't need the key in the ignition to come on just the door opening.
The easiest way to verify is to roll the window down secure the car and walk away. Go back in about 20 minutes and stick your head in through the window. The buzzing should have stopped. Do not open door to check, if you do it will buzz.
THing4CSA (04-03-2018)
If you are sure it is from a parasitic drain, you will need to get a VOM meter and disconnect the negative cable and connect the positive of the VOM to the battery and the negative of the VOM to the battery cable. You should be reading only a few milliamps. Anything 1 AMP or more would indicate a drain. You will then need to remove the fuses in the 2 fuse boxes one at a time. When the meter drops to less than an AMP then the fuse you pulled is the circuit causing the battery drain.
THing4CSA (04-02-2018)
Received 1,442 Likes
Suggest you might review the write-up on Quiescent Current Drain in my sig . . . compiled from a swag of such reported issues in the S-Type forum some years ago, it contains relevant data and methodology for testing and faul6t finding across all modern Jaguars . . . very critical how you do this and the required "sleep" conditions.
Best wishes,
Ken
Best wishes,
Ken
Bruce in North Dakota (04-07-2018)
Battery
Not always so. I have just had to replace my battery for the first time on my eight year old car.
Hi All
Not to disagree with anyone as I know each vehicle is unique. We have only had to change the battery three times over the last 14 years so just about 4.5 years for each.
I will be checking out all the suggestions provided today and see it that does clear the problem. I will post my findings.
Dave
Dave
Hi All
Thank you Avern1 Rolled the window down and after a half hour it is still buzzing; but after 45 minutes it did stop. Next I will check the filter and then go with start with pulling the fuses next to see if that will narrow it down.
Dave, the reference I provided in post #9 gives a QCD of less than 30mA after achieving full "sleep", which IIRC, is given as 60 minutes. If you measure anything more using extension leads on your meter (must not waken car!), then you have a QCD fault that will flatten the battery over the 7-14 days you state. The write-up discusses a systematic approach to pulling fuses (or measuring mV drop across them) to isolate the offending circuit.
By far the most common fault I have seen over many years, is that arising from creative after market wiring of replacement audio units . . . but that is only one possibility of many.
Best wishes,
Ken
Best wishes,
Ken
cat_as_trophy (04-03-2018)
Yes; good idea Dell . . . and I echo you note to *** MODS ***
It is some years since the QCD and Battery 101 write-ups were done and we have since learned, not surprisingly, that many of the issues relate to other contemporary Jaguar models - the X-Types (X400), XK8/XKR (X100), XJ8/XJR (X308).
Cheers.
Ken
Cheers.
Ken
Search, advanced search, title = quiescent battery drain, poster = cat_as_trophy, search now
https://www.jaguarforums.com/forum/s...-drain-123535/
