2004 X-Type Catalytic Converter LH R&I FAQ
Old 01-07-2012, 10:48 PM
jimlombardi's Avatar
Received 1,622 Likes on 874 Posts
Default 2004 X-Type Catalytic Converter LH R&I FAQ
Hi
Forum member rf69 asked for help on this issue in this new posting (post #1):
https://www.jaguarforums.com/forum/x...-3-0-v6-66235/
The LH means that these procedures are for the Left Hand side of the exhaust system.
Look at this 2004 X-Type Exhaust System information from the JTIS21 that gives general description informance and illustrations:
2004 X-Type Exhaust System Description.pdf
I started another new thread for the Right Hand side of the exhaust system. I was going to include it in this thread but the PDF files are too large (or there is a problem with the attachment upload) to include in this posting.
Other new thread weblink (post #1):
https://www.jaguarforums.com/forum/x...36/#post451809
Here are 7 PDF files I created from the JTIS21 Shop Repair Manual for the 2004 X-Type Catalytic Converter Left Hand Side Removal & Install:
2004 X-Type Catalytic Converter LH.pdf
2004 X-Type disconnect battery ground cable.pdf
2004 X-Type Cooling Motor and Shroud.pdf
2004 X-Type Air Cleaner R&I.pdf
2004 X-Type Air Cleaner Element R&I.pdf
2004 X-Type Cooling System Draining & Filling & Bleeding.pdf
2004 X-Type Radiator Splash Shield.pdf
Good Luck
I hope this information is what you were requesting.
Jim Lombardi
The following 2 users liked this post by jimlombardi:
Cadillac (01-08-2012), rf69 (01-08-2012)
Old 01-08-2012, 03:50 AM
Cadillac's Avatar
Thanks jim, I appreciate that
Old 01-08-2012, 12:34 PM
rf69's Avatar
Thanks a lot Jim, I am downloading Acrobat reader to look at what you sent me it should be very usefull
Old 01-08-2012, 02:41 PM
rf69's Avatar
Thanks man I was able to see all I needed downloading adobe reader and I really thak you for all you did. I have a project to do now, I have lovated the front cat (LH)converter At $188 US in catalicconverterswarehouse.com but the rear (RH) I found it in Autopartswarehouse.com at $244 US but I am not planing to replace that one because my auto scanner does not show that is bad yet so I can safe some money :0)
Aus V8S
11-13-2015 11:01 AM
Thang Nguyen
10-12-2015 01:25 AM
skadmiri1
09-09-2015 11:27 AM
rachelstr
09-03-2015 12:59 PM
Quick Reply: 2004 X-Type Catalytic Converter LH R&I FAQ
