2004 X type, CD Error
Guest
Posts: n/a
My 6 year old son shoved a cd in while one was already in the player, I managed to get them both out but now the player will not accept CD's and diplays a "CD Error" message. Any Suggestions. If no one can suggest a way to cure this without changing the CD player does anyone know how to remove the CD player?
Received 3,887 Likes
Because a CD was forced into the CD player, it is very likely that damage was done to the tray mechanism of the player. So, unfortunately, without pulling the radio out, opening up the internals and fixing whatever is broken (provided you can get the pieces you need), the more likely option is simply replacing the radio.
I guess I need to ask, will the radio still pull a CD into the radio? If yes, then your most likely problem is with the laser head. If it won't pull a CD in, then you are looking at the insertion mechanism.
Removing the radio should be as simple as removing the trim from around the radio, removing the screws holding the radio into the dash and then sliding the radio straight out. Once you can access the back of the radio, undo the plugs and remove from the dash.
FS[Western US]: XJS Wiper Motor Upgrade- 76-88 - Electrolux Style
XJsc-guy
09-02-2015 11:43 AM
