2004 x-type, drive-train whine followed by slipping
Does this sound a case of low/bad fluid, or is it a burned lsd clutch... the car was making slight drive-train whine only on acceleration (intermittently, not regularly) after the winter, then it just started slipping. Would changing the fluid do anything now or am I looking at replacing the faulty xfer case/transmission?
I was under the impression that the 2004+ models did not have the same transmission issues. It has 70,000 miles.
Sorry to drop in just to ask a troubleshooting question, but hopefully somebody else has had a similar issue!
Thanks.
Thanks.
So, word back from the transmission shop - it's definitely transfer case and it is completely disconnected internally - output side has no connection to the input side.
Anybody know what this could be? I thought the 2004+ jags were less likely to have these issues, and this particular one only has 75,000 miles on it.
Thanks for the help so far DKurtti.
From everything I've read, any year TC will fit in any year X-Type, Auto or manual. Do you need one with the viscous coupling? Does the car have DSC? Or are you asking to make finding one easier? At the bare minimum I would do bearings and seals. Setting the preload on the bearings is very important. Again, I've never done any of this, but no one else is responding so I'll help the best I can.
Thang Nguyen
10-12-2015 01:25 AM
