2004 x type marker lights
Are you talking the front marker light, up near the front bumper or the one half way down?
The front one comes on with my lights, my lights come on when I turn on the engine. Canada requires daytime running lights so the only light that doesn't come on arte my dash lights.
The middle one only with the signal.
Received 3,887 Likes
Sarver, first, check fuse F38 to make sure that it is good. It is very possible that the fuse blew and that is causing all your problems. If that is good, then what you will need to have your husband do is pull out the headlight switch and using a multimeter, see if 12 VDC exists on the red wire going into the headlight switch. If you have 12 VDC there, then you have a bad headlight switch. If you don't have 12 VDC there, then you have a bad wire between the fuse box and the headlight switch.
If you need more help, let me know. We will get the car back to 100%. On a side note, if you are not too far from Richmond/Southern Maryland and you don't mind a little bit of a drive, I am over in Southern Maryland (near California, MD) and I do a lot with automotive wiring and could probably help put a little bit of light on the subject.
stanjag
08-30-2015 10:35 AM
NinoGrimace
08-26-2015 05:15 AM
