2005 X-type Error codes help please
I posted before and hadn't had much time to work on it. Was getting a few codes when vehicle was purchased. Replaced the O2 sensor for P1647 with a Bosch universal but it didn't work. Replaced that with a Denso OEM replacement and was fine. Of course my luck I now get a P1646 which is bank 1 upflow (firewall before cat). Will replace that with another Denso. Got a P0447 code and was told to replace the purge valve (against the firewall) but that didn;t do it. Apparently there is another valve at the vapor canister that is covered by this code. Any idea where this is located on a 2005 X-Type 3.0? Apparently it is part number C2S8605.
Another issue that arose is no AM/FM radio reception. Apparently there is a digital amp for the antenna. Location of this too?
Thanks!
Thanks!
