2008 X type 2.2 Diesel Bonnet lock will not open.
Went to open my bonnet this morning and lock will not function on one side. I looked and saw that it is a common problem and I followed the advice to open it manually from underneath. I put the car up on ramps and removed the plastic tray from under the bumper and although I can see up side of rad I cannot see the lock mechanism. Video shows it being opened with a long bar but I cannot even see the lock. The one in the video is a 2003 so is there a difference with the later models? Can anyone give me some ideas of how to go about opening it please.Do I need to remove all the under trays ? or is there another way of opening it. Thanks in advance.
NOW GETTING A BIT DESPERATE. on my model you cannot see the latches from underneath !!! have seen some posts about going in through the wheel arch ?? anybody have any experience of this problem please PLEASE.
Had a similar problem with my 05 Estate Wagon. To the best of my knowledge, the hood release mechanisms are the same on all of the X-types. The only variable I see that's possibly relevant different is the diesel engine. When I got mine open it was by removing the plastic underpan, crawling under the car and pushing the release levers with a long screwdriver. They are easilyvisible and, unless your hood release cable is broken, you should be able slide a screwdriver along it and push the lever the cable is attached to. It was difficult and lrustrating as was running the new cable into the engine compartment.
Nothing more I can suggest except wrapping a zip tie around the release lever and the cable so it can't fall off; that was the problem with mine. Good luck!
Hope you got it sorted and would love to h us how you did if so we we’ve exhausted ideas.
Joe Gandalf
05-11-2021 11:46 PM
