2008 X-Type TPMS
Old 08-24-2022 | 09:46 AM
EastRando's Avatar
Default 2008 X-Type TPMS
I'm trying to get my dad's X-Type ready to sell*. It's a 2008 and has TPMS. There's a TPMS system failure warning on the dashboard. My mom said that the tire shop said that one or more of the sensors had failed, and that we'd have to take it to a dealer to have the sensors programmed to the car. My questions are as follows:
  1. Do the sensors really need to be programmed to the car by a dealer?
  2. Can I just have the tire shop replace the sensors and drive around for a while for them to calibrate?
  3. Do I need to go with OEM sensors or are the cheap ones on Ebay good enough?
Thank you!
*He has Parkinson's and can't drive anymore. I'd take the car, but I have an XJS and that is enough Jaguars for me.
Old 08-24-2022 | 01:50 PM
Dell Gailey's Avatar
https://parts.jaguarpalmbeach.com/pr...earchTerm=Tpms
Why is Jaguar X-Type tire pressure light on?
If Jaguar X-Type TPMS warning light comes on and stays on, it means at least one of the tires is underinflated. If TPMS warning light goes on and off, fluctuating ambient temperatures may be the reason. If Jaguar X-Type TPMS warning light flashes for 90 seconds when you start the vehicle and then remains illuminated, the TPMS is not functioning properly and you should have it serviced.
Old 08-25-2022 | 09:42 AM
EastRando's Avatar
Thanks, Dell. It's not indicating that the tires are under-inflated, and I've checked with a gauge, but that there's a TPMS system fault. And the tire place checked the sensors and one or more are not transmitting. My question is, do I need to go to a dealer to get the sensors matched to the car, or can I just buy new sensors and have the tire place swap them? And are the after-market sensors OK?
Old 08-25-2022 | 05:03 PM
sov211's Avatar
The TPMS sensors do not need to be programmed. They are programmed simply by driving the car for several miles.
EastRando (08-26-2022)
Old 08-25-2022 | 06:38 PM
Is there a tpms reset button under the steering wheel? (Underside)
Old 08-26-2022 | 08:57 AM
EastRando's Avatar
Thank you, sov211. I'll probably go with OEM Siemens sensors and have a tire shop fit them.
Dell, I don't know if there's a TPMS button. I'll check next time I'm in the car.
Old 08-29-2022 | 11:12 AM
EastRando's Avatar
Quick update: no TPMS button under the steering wheel. I decided to order Continental 315 MHz TPMS sensors, which are the replacements for the original Siemens VDO sensors. Will report back once they arrive.
Old 09-07-2022 | 09:14 AM
EastRando's Avatar
Continental VDO 315 MHz sensors were replaced by a gas station. No programming needed. No resetting needed. No activation needed. They just worked after driving a few times!
Old 09-07-2022 | 02:59 PM
Nice! Appreciate closing out the thread with results.
pipper678
04-27-2024 11:24 AM
Csanch
12-14-2021 10:04 AM
danke
F-Pace (X761) / C-X17
01-23-2020 07:43 PM
SPiDi
01-16-2020 12:11 PM
ilwill77
03-03-2013 08:46 AM
Quick Reply: 2008 X-Type TPMS
