245/35/r20 tyres
I recently got 20" rims on my '03 2.5L x-type and I still have a lot of clearance from the fender. I think made a mistake though i think by putting in 225/30/r20 tyres cos they only come in 85 load rating where as default load rating for x-type is 92. Car is fine with just me in it but if i have 1 more person sit in it on bumps etc its not very friendly.
Anyway So I have decided to increase load rating by getting 245/35/r20 tyres. This will mean I need 20mm more clearance from the side wall (if that's what you call it) and only it only increases the tyre overall diameter by 16mm which means it will still fit the car without rubbing on the fender. To get more clearance from the side wall I have ordered a 1.25" wheel spacer for the front and rear which means 32mm more clearance and since the diameter of the tyre is enough so tyres will not be touching the fender I am hoping for some nice wide wheels that stick out a bit.
I am not very experienced so I would like to hear what some more experienced people would like to say about this.
Proper spacers will allow you to fit these tires, but you need to know the wheel specs to do this correctly. The wheel width and offset will determine where the wheel/tire sits in the wheel well. I like to start with this handy tool to compare tire and wheel combos...
Custom rims, wheel tire packages for your ride - RIMSnTIRES.com
Measure the clearances on the car (all 4 corners), measure them again with people in the back seat, then order the appropriate width spacers/adapters.
I use billet spacers/adapters that are both wheel and hub centric to ensure a smooth ride...
Stuart Beattie (07-12-2013)
I haven't had my car lowered fortunately. The thing is I have 225/30/r20 at the moment with 3cm clearance on either side and the top from the fender. Increasing to 245/35/r20 my wheel diameter is only increases by 18mm. Putting 225/35/r20 tyres will only increase diameter by 11mm. According to the website above neither 225/35/r20 nor the 245/35/r20 will fit in the x-type but i have seen people with 225/35/r20 tyres on car-domain. they don't seem to complain about rubbing and from the photos you can tell that there is still some space between the wheel and the fender. Am I missing something here?
i guess i found out what i am missing lol. its the fact that when people are sitting in the car obviously i will notice a lot of rubbing unless somehow i raise the car or shave off the fender.
![Cool](https://www.jaguarforums.com/forum/images/icons/icon6.gif)
I had wide rims before but they were only 18".
In the UK, you are ***B R A K I N G ***T H E *** L A W ! if your wheels break the shadow of your wheel arches. IE, if they "stick out"
Don't get me wrong, many people have oversized wheels, geez they look GREAT, but if they are too big, you'll get in trouble and insurance won't touch you, they'll leave you high and dry.
The other thing is clearance and you will know this if you turn the wheel all the way and have someone outside your car for personal investigation.
The recommended wheel is 16" for the X Type and some came with 17" in the later models, I don't know of an 18" model release, but that is as far as you can go, I am sure. 19" is definately a risk any higher, be careful.
having it lowered will allow more space, but you will contradict the other spec/sizing, I am sure.
Can you show a pic, the guys here will know for sure and it's good to get a visual when we are just guessing.
Sorry to put you on a downer, but better to be safe, as Mum says!! That was my theory shot!
Regards, Stu
Last edited by Stuart Beattie; 07-12-2013 at 08:55 AM. Reason: To put in request for pics
I'm not an expert, but you may have a mishap on the road and it'll be an expensive mistake!
Sorry to put you on a downer, but better to be safe, as Mum says!! That was my theory shot!![Smile](https://www.jaguarforums.com/forum/images/smilies/smile.gif)
Regards, Stu![Smile](https://www.jaguarforums.com/forum/images/smilies/smile.gif)
Regards, Stu
18" and 225/40/18 is a factory wheel size and tire fitment.
A 225/30/20 is within 0.9% of a 225/40/18. With the same offset and appropriate load rating, you'd pass MOT all day long.
I rolled my fenders, I had to roll them to fit my wheel and tire package. I spent a lot of time doing it, hours and hours, since it was my first time rolling fenders. If it wasn't for the fact that I wanted the widest tires I could fit (but I should have gotten 255/30/19) on my car for the extra grip, I would have gotten smaller tires and saved myself the trouble. However, now that I have them on the car and everything, I'm glad to have them. The grip is amazing, and they look awesome.
hey justin what spacers did u use? i see 245/30/20 tyres with 93 load rating
Achilles ATR Sport 245/30R20XL 93W All-SeasonUTQG: 400-AA-A
According to website above it will be 40mm closer to brakes and suspension so I think 1.5" spacers should solve that issue. And gaining an extra 1/2" with the fender roller will solve the extra 6mm clearance that I need. The above tyres look really good because of the load rating and fact that they are all-season and with rating of 400AAA meaning they will last a nice amount of time also.
also i am glad i got things cleared up in my head about puting wheels and spacers for anyone who wants to do it on their jag.
![Big Grin](https://www.jaguarforums.com/forum/images/smilies/biggrin.gif)
Spacers retain the same bolt pattern and wedge material between the wheel and the hub in order to push the wheel outward.
with regards to raising the car... what is the best way to do it. i have seen coil spring spacers and some people say you can get longer springs. if i get longer springs will it raise the car a little. these are the current specs of the springs that jaguar x-type takes.
Front Coil Springs
Pigtailed at Both Ends
Coil Thickness:13mm
Overall Width:163mm
Overall Height:448mm
Rear Coil Springs
Cylindrical Top & Bottom
Coil Thickness:12.25mm
Overall Width:118mm
Overall Height:363mm
Front Coil Springs
Coil Thickness:13mm
Overall Width:163mm
Rear Coil Springs
Overall Width:118mm
Yes, in a way they are, since they do space the wheels out, but I didn't use my adaptors either. I lucked out and found wheels that are the right bolt pattern and offset and everything I wanted so I didn't need them.
